I would like to know if the subframe from a 65 hardtop will bolt up correctly to a 64 wagon. Are they the same? Thanks for any help.
Yes its the same subframe and will bolt up. The radiator support might be different at the headlight area on the 65 so you might need to reuse the 64 rad support.
63-65 would all interchange & it doesn't matter if it is a sedan, wagon, or hardtop. The 65 core support is different due to grille brackets. 63-65 also use the same hood hinges so you can reuse yours. 62 is it's own on the hinge to inner fender panel bolt spacing though.
