The easiest way is to remove the steering wheel from the column, unbolt the column from the floor and remove the column. Then raise the car, unbolt the left side motor mount and raise the engine two inches or so. After this prep work, you're ready to remove the box/shaft assembly.
Been there, done that!
Chuck
