The relay is grounded in the column when you push the horn button.
Tim
Tim
Does that ground get to the relay by way of the tan wire ( which is a black wire from the horn button) going to the relay? (the bottom of the relay has a tan and black wire, the black going to the horns), if yes I've grounded that side of the relay and the horn does not blow.The relay is grounded in the column when you push the horn button.
Tim
