If you are still using the stock front end and would like a nice 1962 idler arm,Call Novajoe!
The 62 arm drops down and the 63-67 is inset into the subframe a lil bit.
If you want to upgrade to a 63-67 design,you will need to modify your pass inner fender skirt to except a 63-67 arm
You can make something work.by cutting a hole in the subframe like the 63-67's have.
OR:
Replace the inner fenders to a 63-64.
You will need to change all the front end components to a 63-65 type such as:
idler arm
pitman arm
center link
inner and outer tie rod ends.
hood hinges.
Do yourself a favor:
Go with a churchboys or CPP kit!
