141 - 160 of 181 Posts
Discussion Starter · #142 ·
Pro tip: spend more time masking, less cleaning, don't ask me how I know....🙄
First I sanded the inside of the rear bumper, cleaned it and sprayed it with a rust converter/primer followed by a coat of black paint.
I cleaned the rear wheels and while they were off I checked my brake shoes.... I had no experience with this and mounted the front and rear shoes the wrong way round on 1 side of the car....so that is checked and fixed now too.
I de-rusted the license plate light housing, polished the lens, painted the housing and added a ground wire for trouble-free operation.
Then I cleaned and plastic dipped the rear bumper, mounted the license plate and then the bumper on the car. Good progress 😃
Road surface Asphalt Grass Motor vehicle Bumper
Hand Automotive lighting Finger Gesture Wood
Vehicle Motor vehicle Car Automotive lighting Hood
Tire Wheel Vehicle Car Automotive tire
Tire Wheel Vehicle Automotive tire Car
Tire Wheel Car Vehicle Land vehicle
Car Vehicle Tire Automotive parking light Automotive tire
Land vehicle Vehicle Car Motor vehicle Automotive tail & brake light
Discussion Starter · #143 ·
I wanted to have the trunk lid finished before it went to the upholsterer... didn't quite make it though. The inside is painted and the outside is still in primer so after I mounted it I covered it in plastic for transport. Drove it up the trailer on it's own power. It does take a lot of turns lock to lock on the steering.... might need a quick ratio box in the future.
Now it is gone to have the headliner installed..... and maybe I'll have him do the rear seat too.... if budget alllowes. This is the only Nova I know of that has a factory arm rest... (probably an option only available in Switzerland where this body came from)
Wood Gas Circle Ceiling Art
Sensitive content, not recommended for those under 18
Show Content
Chin Jaw Wood Plaster Stain
Scale Wood Bumper Automotive exterior Gas
Hood Wood Automotive lighting Gas Bumper
Automotive exterior Wood Gas Bumper Vehicle
Bumper Wood Automotive exterior Gas Electronic instrument
Vehicle Hood Vehicle registration plate Car Motor vehicle
Hood Vehicle Motor vehicle Automotive exterior Automotive design
Tire Wheel Car Vehicle Window
Wheel Tire Vehicle Car Automotive tire
Discussion Starter · #144 ·
A small job done is still q job done.... sprayed the trunk emblem black with plasti dip and then painted the center with enamel paint.
Trunk emblem is 63, hood is 62... I think their styles match well. Trunk emblem is done, working on hood emblem now.
Wood Floor Flooring Gas Concrete
Automotive tire Track Wood Rolling Railway
Paint Fluid Gas Font Electric blue
Hood Wood Writing implement Tints and shades Flooring
Motor vehicle Wood Font Automotive exterior Rectangle
Wood Rectangle Tints and shades Composite material Natural material
nice job. this is my first time seeing pillars covered with vinyl, very creative; it spices up a pretty bland area. have seen so many of these cars now, seeing something new is refreshing.
what vendor did you purchase the windlacing from?
-Rusty
Discussion Starter · #149 ·
Thanks guys!
Rusty, I got the windlace from a company here in the Netherlands that sells all kind of rubbers. I just looked at the dimensions of the original and ordered based on that. Vinyl on the B pillar was actually used originally on the Swiss donor car I bought. It also had an armrest in the rear seat! Never seen that before on Nova's.
Discussion Starter · #150 ·
Also received the smaller trim/windlace for the front and rear of the headliner... 10 minute job to install that. I have plans for the center console, base is a mark 1 Volkswagen Golf (rabbit) console, I'll use the cloth with epoxy resin to get the basic shapes.
Hand Gesture Thumb Finger Tool
Hood Automotive tire Automotive design Motor vehicle Automotive lighting
Sleeve Motor vehicle Automotive design Comfort Vehicle
Vehicle Motor vehicle Car Hood Light
Thanks guys!
the lower end Chevy ll's didn't have the rear seat arm rests. the 400 model an ss model did have the arm rest. there is a pair of rear arm rest bases for sale on steves site at the present, if your looking.
  • Like
Reactions: Martin71RS
Discussion Starter · #157 ·
Some progress on the center console.... smoothed with body filler, covered with foam and vinyl and made aluminum trim pieces. Made some brackets to secure the console in place an welded them to the tunnel. I can tighten the bolts through the radio opening. Not done yet but getting there.
Hood Automotive lighting Motor vehicle Wood Bumper
Hood Automotive tire Automotive design Wood Automotive exterior
Automotive tire Wood Automotive lighting Gas Electrical wiring
Automotive tire Bumper Automotive exterior Asphalt Gas
Vehicle Car Motor vehicle Steering wheel Automobile pedal
Vehicle Hood Steering part Automotive tire Motor vehicle
Wheel Automotive tire Automotive lighting Hood Tire
Automotive tire Motor vehicle Automotive design Bumper Hood
Motor vehicle Hood Automotive tire Automotive lighting Automotive design
Discussion Starter · #158 ·
Since the passenger side kick panel vent connotatie be removed without removing the heater box I made some modifications.
I cut the vent in two and glued the visible part to my kick panel. Made a flange and glued that to the part that holds the vent door so now it can pass through the hole into cowl area. Made a flange that screws to the body and to the part that holds the vent door. Sealed it with rtv gasket and now my panel can easily be mounted and removed if I need access.
Automotive tire Finger Bumper Fender Personal protective equipment
Hood Automotive lighting Grille Automotive tire Automotive design
Automotive tire Gas Automotive exterior Bumper Font
Hand Automotive tire Synthetic rubber Wood Tread
Motor vehicle Automotive tire Hood Automotive design Bumper
Wood Eyewear Automotive exterior Audio equipment Gadget
Automotive tire Automotive lighting Motor vehicle Hood Vehicle
Automotive tire Motor vehicle Grey Automotive design Automotive exterior
Discussion Starter · #159 ·
2022 started with work on the Nova.... the seats are connected electrically and I have applied insulation to the floor. I didn't have enough, just needed a bit more material so I ordered that so I can finish it this week.
Automotive lighting Motor vehicle Hood Automotive design Trunk
Vehicle Motor vehicle Hood Automotive design Car
Hood Automotive tire Automotive lighting Motor vehicle Grey
Discussion Starter · #160 ·
Did the final bit of insulation ran a tap through the seat mounting nuts and a die over the bolts since they were clogged with paint and underbody coating. Some copper grease and now they go in as they should. I welded a brace between the seat frames to make it stronger and easier to install. Ground them to bare metal, enlarged the bolt holes a tiny bit, bevelled the edges and gave them a coat of primer.
I've put in the carpet today. Still need to make holes for the seat bolts and the high beam light switch.
Slowly it's starting to look like a car again. 😃
Next time make the holes, paint the seat frames and clean the seats before I install them (hopefully for the last time, they weigh a ton)
Wood Automotive exterior Composite material Flooring Gas
Rectangle Wood Material property Flooring Font
Wood Tread Automotive tire Tire Flooring
Wood Tool Fastener Gas Screw
Hood Motor vehicle Automotive lighting Automotive tire Automotive design
Car Vehicle Motor vehicle Automobile pedal Automotive design
Vehicle Motor vehicle Hood Automotive design Automotive tire
Motor vehicle Automotive tire Car Vehicle Automotive design
Car Vehicle Motor vehicle Steering wheel Steering part
u
