101 - 120 of 141 Posts
Discussion Starter · #102 ·
It has been a long time since the last update.... I bought another garage, broke out the walls and made 1 out of 3... makes working on my projects a lot easier. I did do some work on the Nova.... made an exhaust, finished the trans tunnel and removed the paint from the doors. I cleaned and lubricated the latches and installed the doors.
In the last years I've spent a lot of time working on my Camaro and I've built a few bikes...but now it is time to get back to the Nova.... I want it finished!
I just got a new battery so I will be able to start it and move it around if needed....
Motor vehicle Automotive tire Transport Fender Automotive exterior
Motor vehicle Automotive exhaust Suspension part Automotive engine part Automotive fuel system
Motor vehicle Mode of transport Automotive tire Transport Automotive wheel system
Automotive exhaust Auto part Pipe Exhaust system Muffler
Silver Synthetic rubber Wire Steel
Motor vehicle Wheel Vehicle Land vehicle Automotive design
Vehicle Land vehicle Car Fender Vehicle door
Motor vehicle Vehicle Land vehicle Car Fender
Fender Alloy wheel Metal Auto part Machine
Discussion Starter · #104 ·
First job done.... battery came in and I made a hold down strip for it. This 64AH Exude fits perfectly! Plenty of power and it starts up quick now.
Cable Wire Electrical wiring Electronics accessory Synthetic rubber
Gas Machine Electrical wiring Fuel line Nut
Orange Tan Composite material Steel Artisan
Cable Technology Wire Electrical wiring Engine
Machine Gas Cable Electrical supply Wire
Writing implement Stationery Office supplies Pen Metal
Machine Wire
Line Metal Iron Steel Silver
Brown Fender Rim Automotive wheel system Tan
Cable Technology Wire Electrical wiring Electrical supply
Discussion Starter · #106 · (Edited)
414554
414555
414556
414557
414558
414559
414560
Did some work the past weeks.. installed the mirrors, had to drill a new hole and will have to weld the unused holes shut. I also started at bodywork... first time hammer and dolly work but i took it slow and with some tutorials on youtube i got stuff done. Not perfect but good enough that with a skimcoat of filler it will be nice. All trim will be black, i had the door handles powdercoated for a durable finish. The chrome was pitted so that does show a bit but i don't mind since it will not be a showcar. Assembled them with new o rings and installed them on the doors.
Slow progress is still progress :) !
Discussion Starter · #107 ·
Cleaning door internals and mounting them so I am sure I have everything and it all works. Best to do this before paint I think. Feels good to be back working on the Nova again!
414688
414689
414690
414691
414692
Discussion Starter · #108 ·
I could not get the fenders aligned properly....... removed the hood and hinges, loosened the front clip and took out some shims between clip and body. Bolt holes line up nicely now on the drivers side, gap between door and fender are better now and more adjustable. Next is passenger side. Step by step .... :)
Motor vehicle Hood Bumper Automotive exterior Gas
414814
414815
414816
414817
Discussion Starter · #109 ·
The 10SI regulator was broken so I upgraded to a 12SI with 94A output... Nice to have with the stereo and electric power steering.
Automotive tire Automotive alternator Gas Automotive wheel system Motor vehicle
Land vehicle Car Vehicle Motor vehicle Hood
changed out the H4 headlights for LED... what a difference, so much light :cool:
Car Automotive parking light Vehicle Vehicle registration plate Grille
Automotive parking light Vehicle Grille Automotive lighting Hood
removed some more paint since I decided to tackle most of the preparation myself. I will be painting everything but the large exterior parts. I will spray epoxy primer on everything. The door jambs, window openings and inside of the doors is doable for a novice painter I think. The car will be BMW white, a bright wite and the chrome will be black.
Tire Wheel Vehicle Car Automotive tire
The cowl area on the passenger side turned out to be a bit too high. I've done a lot of welding on the body so I probably messed up a bit there.... so out came the grinder and welder...
Automotive parking light Automotive lighting Hood Automotive tire Vehicle
Automotive tire Wood Bumper Waist Tints and shades
Tire Hood Automotive tire Dress Grey
Hood Motor vehicle Automotive tire Bumper Orange
Discussion Starter · #110 ·
After grinding down the welds I applied filler and did some shaping. Applied some primer to prevent rust, I will final sand and apply epoxy primer when it is delivered. I drilled all hinges for guide pins to make assembly easier and take out the guess work. After that I took out the doors and disassembled them so I can prepare them for paint.
Making progress!
Motor vehicle Hood Automotive tire Automotive design Vehicle
Gas Automotive lighting Machine Metal Fashion accessory
Wood Gas Wood stain Metal Automotive exterior
Automotive lighting Hood Automotive tire Motor vehicle Bumper
Hood Automotive tire Motor vehicle Automotive lighting Sleeve
Wheel Tire Car Vehicle Motor vehicle
Motor vehicle Automotive design Gas Auto part Machine
Car Vehicle Motor vehicle Hood Automotive design
Vehicle Car Motor vehicle Hood Automotive tire
Fixture Gas Automotive exterior Composite material Bumper
good update, great work so far.
remember to check your spec sheet with the epoxy primer. you may have to put primer over it within a day or so, otherwise it has to be stripped or heavily sanded for anything to stick to it chemically. at least that is how the PPG epoxy was for me. and let me tell you, that stuff really clogs sandpaper!
-Rusty
Discussion Starter · #112 ·
Did some work again on the Nova.. . Painted the sealer on the A pillar drip moulding, fixed 2 small dents in the roof, the area under the windshield I modified earlier and some other spots here and there. Sanded the rear quarters too and put 2K epoxy primer on to protect them. It looks good in the pics but there's plenty of work to do with filler and sanding. At least it's progress! :cool:
417564
417565
417566
417567
417568
417569
417570
417571
Discussion Starter · #116 ·
Filler and sanding.... The right tail light panel seam was different from the left (which is as it is supposed to be). The right side seam was filled with lead, I filed away a bit of the lead and shaped it to match the left side. Now it's a matter of finding all the low spots, fill them and sand back again. Not my favourite job but it must be done.
418519
418520
418521
418522
418523
418524
418525
418526
418527
Discussion Starter · #118 ·
some progress again....bought sanding blocks and quality sandpaper.... makes the job easier....still lots of work! First pass with the 16"block and 60 grit to get the basis, covered with thin layer of epoxy primer for protection and to see it in 1 color.
I added some old pics so you can see what the basis was.
419264
419265
419266
419267
419268
419269
419270
Discussion Starter · #119 ·
I wasn't happy with the lines on the right quarter panel so sanding, filler and more sanding. Still not finished but satisfied with the result sofar.
419382
419383
419384
419385
my first nova back in 67-69 was a 62 4 door 400 model. i sure wish i had kept that one. your doin' a good job there.
  • Like
Reactions: Martin71RS
