1 - 2 of 2 Posts
I put new full qtr panels on my 63 and was wondering what do you guys do to the seam where the rear window meets the qtr, and right behind the at seam where the qtr meets the rear panel above the trunk, the guy that did it put worth seam sealer, but it already cracked and the rear part has a little peaice missing on the dynacorn full qtr panel, i have heard not to weld it because it will crack, but brazing it would be good from a old body guy he also said a sertain type of seam sealer wont crack but brazing would probably be the way to go, any info would be helpful, thanks!
You can braze it and use a two part self leveling seam sealer. Its the same stuff that you can use in your drip rails too.
1 - 2 of 2 Posts
