Before I drop coin on a new tremec tko600,I was wondering if anyone was running a richmond 6 speed,and if so,how do you like it,alot of cutting,etc.I really dont want a T-56,only because of all the cutting and Im keeping my bench.Any advice and or info would be great thanks.
Not sure on what you will end up doing but I just put a new tremec tko 600 in my 69. If I would have known about the cutting I might not have done it! However, having that beast in there I wouldn't do anything other than what I did. I have a bench seat and have an 8 inch aluminum shifter with a 1.5 inch offset. I decided to do the cutout myself and I have a friend weld in the tunnel piece. It really isn't bad, and not that hard. Worth the work.
Sent from my iPhone using Autoguide
I just put a TKO-600 in my '63 but wasn't worried about the floor 'cause I was fixin' to replace the whole darn floor anyway. Don't know what you are converting from, but you'll enjoy what you are going to with the 5 speed. It is a sweet piece.
There's nothing like converting from a four speed with 373 gears to a tko with that .64 highway gear and 390's in the back. I can cruse down the hwy at 70 at around 2100 rpm's with my 17 inch rims
im running 18's and 3:70's im going with the tko just seems right....hotrod hydraulics has a nice clutch set up fully adjustable for proper pedal geometry..
You will be able to hit about 76 mph at about 2100 rpm's with that setup if you go with the .64. I think the other 5th gear is like .82 or similar
