Go as small as will loosen the weld. It is worth the cost to buy both sizes and only use the larger one if needed.
A recommendation is to carefully grind out the spot welds in complex and hard to get to areas like the cowl. You run the risk of drilling holes through lower panels that become very difficult to fill weld back together. This can get really creative in areas of the dash, cowl and firewall.
