Is anyone here using pre-bent hard lines for the 4L60e? using quick disconnect? or is everyone just using the NPS fittings and High pressure hose?
I need some visuals and direction on this.
Discussion Starter #2
Nothing?
Anyone have a preference of which lines to run and where? tight to the motor or along the frame?
Your cooler running to the back of the car?
I made AN lines. Russell makes fittings that replace the quick connect fittings in the trans. Ran them to the remote cooler. Came out pretty clean.
Yep... I was recommended not to run through the radiator by my transmission builder in the event of a radiator leak or failure. I'm using a Derale cooler with a fan. I'm actually moving it further back.
I am presuming your set up is more strip then street?
I used Summit AN fittings with 3/8" PTFE braided lines.
I am thinking of doing the same right now, although I did toy with the idea of bending my own lines...
