TROUBLE! Thats what would happen!what would happen?
Yes they can internally balance the 400 assembly. It would not be cheap because of the weights to be added.Sorry about the hijack but I've always wondered, what was the purpose of making the 400 externally balanced? Did they NEED to or were they all just sitting around a table wondering how to screw with the consumer?
Follow up question, can you have a machine shop balance a 400 rotating assembly? If you do, then can you use a 350 balancer and flexplate?
Has to do with the limited space of the SBC and metal density..and above all cost of the casting and machining....Sorry about the hijack but I've always wondered, what was the purpose of making the 400 externally balanced? Did they NEED to or were they all just sitting around a table wondering how to screw with the consumer?
Not enough room in the block for proper counter weight on crank.Sorry about the hijack but I've always wondered, what was the purpose of making the 400 externally balanced? Did they NEED to or were they all just sitting around a table wondering how to screw with the consumer?
or purchase a internal balanced 3.75 stroke crank!!!Yes you can make a 400 a neutral balance.. by adding Mallory metal.. about 1.5 times the density of lead.... a 1.0oz slug last I heard was $75.00... but I could be way off on the cost...as I really dont recall
dont for get the 6" rods for the added counter weight length there big buddy!or purchase a internal balanced 3.75 stroke crank!!!
And then all the bearing spacers!
never mind, just add tungsten weights and have it balanced!:devil:
AL
