a core 400 is worth more than a 350 core ! but they both have there pros & cons .. So it is really a question of intensions , and which if any has quality parts internally .which is better a 400 sbc or a 350 sbc .right now I have a 350 in my nova but my dad has a 400 in his 64 chevy truck and he is selling the truck.if the 400 is a better motor im going motor swap them before he sells it .
unless , you intend to build a performance engine out of the 400 , i would not do the swap . thats my opinion .there both stock the 400 does have a alum intake but it a stock one
And I can think of 50 more to save your money and buy an SHP block.I can think of at least 50 reasons to go with the 400 over the 350...
pops
Then he could do a build up like Tubbed63 mentioned above and never worry about the typical block issues. Only I'd go the other direction and use a 4" stroke and still wing it to 8000+......NOW we're talking about POWER...:devil:
Very conservatively rated at 600.:yes: A Little M would be better---Iron Eagle would be the ultimate. But in either of the latter two cases I wouldn't looking to run 23* heads either.:no::devil: I figured they would ultimately limit the power on the SHP block enough to live just fine.Nahhhhh I wouldn't do that with the SHP block myself. They are only rated up to 600hp. A little M sure that would be wicked! I like the 377 with the factory block because a 2 bolt thats been splayed and properly prepped will handle that just fine. I wouldnt dare do a 434 with a factory block and expect it to stay together long at 8K+.![]()
Reread the op, he has a 350, his dad has a 400. He was not talking about building a complete motor, just a simple swap. The 50 reasons I was talking about were cubic inches..And I can think of 50 more to save your money and buy an SHP block.
