1 - 16 of 16 Posts
if the machine work was done correctly and the bearings and such are a quality piece and installed correctly then yes its a good buy. around me a 400 virgin block that needs to be machined sells for around $300.
nice! yea measure the bores to see where they are at. Its really kinda hard to machine a block for the proper size if you don't have pistons. Not all pistons measure the same so the piston to wall clearance can be too big or too small. Not a big deal though. Be sure to spray it with WD-40 so it doesn't get alot of surface rust on it.
Also those 215 brodies are nice. Got any info on those?
Discussion Starter #13
thanks i did a quick measure on the bore it was 4.150 like i said very quick. the brodix heads have 2.08 in/1.60ex 60cc chambers. they were on 400sbc in a4x4 went 11.30 in the 1/4 put some nos. too it and piston let go.
Do you have pistons already?
1 - 16 of 16 Posts
