1 - 2 of 2 Posts
I am installing a 4 speed in my car and I need help with the brake pedal rod. Which hole on the pedal do I mount it to? It seems that either one does not give me much pedal travel. The car has power brakes. Thanks
Power brakes require using the lower of the two holes in the brake pedal arm. Adjust your clevis rod so that you have about 1/8" end play, and make sure that your brake light switch is still adjusted correctly.
1 - 2 of 2 Posts
