1 - 20 of 141 Posts
I've rebuilt the front end, replaced the shocks and springs all the way around and the car still sits one inch low on the driver's side. Someone suggested putting air shocks in the rear and run to separate lines to level the rear end with the shocks...but that seems like I'm masking the problem. Anyone fix this issue in their car?????
· Premium Member
Are you sure your frame is not bent or twisted? Can you put it on equal sized blocks are all four corners and take measurements. Are your body bushings and spacers correct? Are the body mount points correct? Are you sure the springs are ok. Just because they are new does mean they are good.
Before puting it on blocks, measure the height of your body mounts.
when the car has jack stands under the subframe on all four corners it sits dead level. I would think that it would not sit level if the subframe were bent. Also, every body panel on it but the hood is a factory body panel. When we had the car stripped for restoration there was no apparent damage to the unibody. And it didn't sit like this when I first got it....
I was thinking body mounts might be the issue, but an inch?!?!? that seems to be a HUGE amount for simple body mounts...or am I wrong about that?
I'm considering taking to a local guy that is well known for chassis setup to let him check it out.
· Premium Member
The rear could the culprit, to high or binding and causing the front to sit low. I know it's a pain, but, how about swapping the front coils from side to side?
Discussion Starter · #7 ·
The rear is the problem, it does male the front left sit a bit lower but I'm petty sure the back is the issue. I could've swore that putting in the CalTracs and split mono's would have helped it.
· Premium Member
My red Nova in my siggy is the same (front driver side low), but the car was raced hard most of it's life and the rear suspension is showing it's age and wear.
· Premium Member
Oh ya, I couldn't get full throttle because mine were so bad, it could also be a rotted bushing mount Novas subframe are known for this too! Wouldn't hurt to check.
Discussion Starter · #15 ·
it just leans, it drives straight as an arrow...
I'll try looking at the body bushings later this week. That was my next avenue but I figured it would be impossible for just some body mounts to do that.
Discussion Starter · #20 ·
You could swap sides with the rear leafs and try that...I ordered new rear springs for my '56 Chevy and it turned out one was arched more than the other. By the way your car sure did turn out nice.:)
Thanks for the compliment on the car! At this point I need to let someone else look at it...I'm kinda frustrated with this one issue. :)
1 - 20 of 141 Posts
