Hello All,
Looking to see if anyone has the length to start with, don't need the size on the wider end that goes around the front clip area size just the tubing. I am in a welding course for a few weeks and with the Canadian Exchange rate they are way to much to buy so I want to make them if I can. If anyone has the length of each section to the weld and even the angle that would be better. I made up 1 using plastic eavestrough as it is light and you can tape it together but knowing the real length would be better then my guess and guessing at the angles.
Thanks for reading.
Thanks for reading.
