This is a great round up of gauge panel options! Thanks
@exotec for tagging me here. Below is a recent photo of my 3D print cluster insert during mockup. In this photo it's literally just sitting in place so I could check fitment with things in the car. The plan is to fill and sand out the layer lines, paint the whole piece black, then add chrome on the raised edges / trim rings. I looked at a ton of early 70s interiors looking for ideas before I designed this. It required cutting out some areas of the original panel, which I did with a Dremel tool and round carbide bit.
@kimmer71 you mentioned concerns about cutting the brittle original piece. This was a concern for me also, because several of the mounting posts were cracked or broken off on mine. I found it actually cut easily with the Dremel and felt like new plastic as I cut through. I used JB Weld Plastic Bonder 2 part adhesive to repair the posts and some cracks; it is shockingly strong. I'm not trying to encourage you to go this route though, because I think an all metal dash is also a great option and would be a great way to continue building your already-great metal working skills. For ideas, take a look at
1969camaroskunkworks on Instagram; he fabricates these for Camaros and Novas and he has a few posts where you can see the individual pieces as he's making the panels.
