Will a 4th gen 8.5 10 bolt right into a 3rd gen?
3rd and 4th gens have the same rear suspension. The overall width of the rear and the spring locations are identical. The only difference is 1976-79 Novas could have a 7.5" 10-bolt rear that has a smaller center section and requires a 1" longer driveshaft than 8.2" and 8.5" 10-bolts. However, you don't want a 7.5" 10-bolt. Find a 4th gen with a 8.5" 10-bolt and it will directly bolt into a 3rd gen.I think the overall width and width between the spring perches is wider on the 4th generation.
Not with an 7.5" The 7.5" requires a 1" longer driveshaft than a 8.2" 10-bolt, 8.5" 10-bolt and a 12-bolt.It will bolt right in and the drive shaft will work with a 7.5,8.5,12blt, i put a 70' 12bolt nova rear into my 78' that had the 7.5, and put the 12blt into the 74' that had a 8.5 everything will fit and work.
NO i kept the orginal drive shafts and th350's with the cars, Just had the rear, it was from a 1970 nova SS 350 4 speed car that was wrecked, i got the rear for $50. I had every combo and it all worked fine, even with my now th400. My 78 was a I-6 250 car with a th350 and 7.5" 2.41 geared rear.Not with an 7.5" The 7.5" requires a 1" longer driveshaft than a 8.2" 10-bolt, 8.5" 10-bolt and a 12-bolt.
What you probably did was install the '70 12-bolt and the 1970 driveshaft into your '78 that has the 7.5". That would work.
