I have a 71 nova with a 388 stroker, it has vortec 906 heads, and 467 lift crane cam, and hypertonic flat top pistons, 750 edelbrock cam, dual plane air gap crosswind 1500-6500rpm intake. When ever I push the gas past half throttle and let go, the engine backfires out of the drivers side header. And also when i go to take off fast the engine hesitates sounds like its choking out, and then it wil go but seems like maybe not all the power is there. The timing is set to 12 degress and a total of 36 degrees, which i need to get a new distributor with a timing curve. The total i belive is suppose to be 34 degrees. I checked the top dead cent to the crank timing marker and it is dead on. Any ideas please help.. Thanks
