Need opinions on this , talked with my builder today , i want a 70-72 Nova , 6.80's-7.0 , he says i can get away with my 292 heads , big hydraulic , looking at a Edelbrock 4+4 intake cause these heads are ported to a 1206 gasket and the 4+4 ( kinda big i know ) i'm looking at has been too. 5500 converter , so low rpm manners not required. I figure the personal challenge will be to see how fast i can get a 388 car with a big hydraulic to go. Thinking of using a 488-513-538 gear with a glide with a 28-29 inch tire
388 approx 11.0 comp , target max rpm 7400
700 dp on a 2 inch spacer to start with , work with carbs from there , consistantcy will also be a deciding factor in all parts selected.
with the size of the converter , thinking i'll need a cam with some rip left in it at 5500 to hit hard at 5500 and still be strong to over 7000
he's got an eagle cast crank , looking at a 5140 or 4130 crank ,, no nitrous planned , 4340 if i was ,,,
looking at this cam
http://www.lunatipower.com/Product.aspx?id=1788&gid=246
i might call them and see if we could take about 5 degrees off the intake lobe
looking at this cam
