Which Comp 284? Hydraulic flat tappet, Hydraulic roller??What should i expect from a 383 stroker its got around 9.5 compresion forged flat top piston 2 valve relief eagle I beam rods cast crank cam is a comp 284 dart steel heads with 2.02 /1.60:
Well i hope that it does to, But i guess i was looking for rough hp and tq so maybe this will help 350-30 over 3.75 crank 5.7 eagle I beam rods TRW pistons heads are dart steel 2.02/1.60 they are about 15 years old it has headers the cam is a comp 284/296 -507/510-240/[email protected] range is 2300-6500rpm no port work that will have to come later weilend intake duel plane has a proform 750 douple pump mec sec maybe give rough 1/4 mile it does have 4/speed m21 and 12bolt 3.73 gears By the way thats a great looking shot of your car out of the holeI would expect it to start and run, hopefully for a long time. What would you expect? I suppose my expectations could be somewhat lower than yours.
Take my last post and fill in the blanks.:yes:Well i hope that it does to, But i guess i was looking for rough hp and tq so maybe this will help 350-30 over 3.75 crank 5.7 eagle I beam rods TRW pistons heads are dart steel 2.02/1.60 they are about 15 years old it has headers the cam is a comp 284/296 -507/510-240/[email protected] range is 2300-6500rpm no port work that will have to come later weilend intake duel plane has a proform 750 douple pump mec sec maybe give rough 1/4 mile it does have 4/speed m21 and 12bolt 3.73 gears By the way thats a great looking shot of your car out of the hole
