shhheeeeeeettttttt you dont need no stinking oil pan....just pour some slick 50 on it and you should be able to drag that thing without an oil pan on itDriveWFO said:Do I need a special oil pan for the 3.75" stroke to clear it? I'm looking for something with a windage tray, trap door, etc. 6-7 quart.
Yeah!! What do you want all that weight on there for??? It'll just slow ya down!!!69NovaSS said:shhheeeeeeettttttt you dont need no stinking oil pan....just pour some slick 50 on it and you should be able to drag that thing without an oil pan on it![]()
What could cause interference on the oil pan with a 3.75" stroke? At how many rpm did you see the 20hp on your setup?bowtie0069 said:As I posted here a while back, I run a Moroso 21016 pan which is a little pricey at $349, but it was good for 20+h.p. on the dyno.
I run a 3.800 stroke and have no clearance issues with Eagle H-beams; some rods are bulkier and could come closer.What could cause interference on the oil pan with a 3.75" stroke?
It made more power everywhere--Matt King ran similar pans(Milodon's w/kickouts) on big and small blocks and saw 20-24 h.p. on the dyno pretty much across the power band.At how many rpm did you see the 20hp on your setup?
Ditto...the added weight of the pan and 5 quarts of oil is just holding ya back Dave...just run 'er without either and you'll be good to go72GreenRally said:Yeah!! What do you want all that weight on there for??? It'll just slow ya down!!!![]()
Randy (and you call yourself Amish!!)![]()
When Matt told me he found that much power I was skeptical; so when we were doing my engine article, I contacted Moroso about doing a sidebar on the power a good pan can make. The comparison was between a basic stock type pan(mine was a Milodon 6 qt.Z/28 clone) We ran the pan with the correct amount of oil; over filled, and underfilled, to see what happened(some slight loss with 2 qts over) then switched to the Moroso--WOW! I don't have the sheets in front of me, but it made more even at 2000-2500, where I would'nt have expected any gains. The main thing with this pan is the kickout on the passenger side that lets the oil be flung away from the crank. It seems to help much more than I would think possible. What was even better, was the cost to me---NADA! ZIP! ZILCH! NUTTIN! Free is one of my favorite words! But I think after seeing the results, I would spend the money on one.but I find it amazing that there is that much HP to be found in the oil pan
I think you know the answer, LOL. $$$$$$$$$$$$$$David_D. said:Why not just go all the way and use a dry sump oil system?![]()
Mike, how do you get access to the pan bolts? It looks like the sides of the pan are buldged out to allow the oil to sling off further away from the crank.bowtie0069 said:As I posted here a while back, I run a Moroso 21016 pan which is a little pricey at $349, but it was good for 20+h.p. on the dyno.
