Maybe I'm off, but I swore a 383 crank IS a 400 crank. If its not, I've got some homework to do.
Hopefully someone else chimes in, cause I'm in lala land right now.
from the factory, no but Since the factory never made a 3.75 stroke with 350 mains any aftermarket crank made this way 99% of the time is going to be slammed in a 4.030 block and that equals a 383:yes:there's no such thing as a 383 crank...
A 406 is just a 400 block that is bored.030".I'm asking cause I want to build a 406...
No offense, but that's a misunderstanding. A "383 crank" will yield different cubic inches depending on the block it's put in, and the bore of the block. The way to get a 383 SBC is to put a 400 crank in a 350 block that is bored 30 over, and the crank has been machined to fit the 350 journals. Put that same "383 crank" in a different block with a different bore and it will give you different cubic inches.There is such a thing as a 383 crank.http://www.chevroletperformance.com/_res/pdf/installation_guides/small_blocks/zz383/ZZ383_Engine.pdf
http://www.crateenginedepot.com/Crankshaft-383ci-4340-Steel-12489436-P9799.aspxthere's no such thing as a 383 crank...
Can that crank be used with fenderwell headers?http://www.crateenginedepot.com/Crankshaft-383ci-4340-Steel-12489436-P9799.aspx
Just to throw ink in the ointment.![]()
Yes you can if you use the bearing spacers.I'm asking cause I want to build a 406, but recently picked up a steal 4340 383 crank and H beam rods for next to nothing and was thinking of using the spacers to build a nice healthy sb 400...
Sounds like he wants to use a 400 crank machined to fit a 350 block in a 400 block.Mopar has made millions of 383 cranks!!
What he is asking is about running a 350 sized journal in the 400 block. Racers have done this for years with few issues.
Some even use undersized bearings with 350 bearings.
So, there really isn't a 383 crank per se, but it would be a crank originally intended for a different engine that has been machined to fit the 350 block.
Yes a 400 crank
Sounds that waySounds like he wants to use a 400 crank machined to fit a 350 block in a 400 block.![]()
Would be easier and cheaper.:yes:Sounds that wayjust get a 400 crank??
Not the factory 383; they use a 3.800" like I run in my 410" (.020" over 400) or my old 414" (.030" over 400)a 383 crank is a 3.75 stroker crank
