1 - 11 of 11 Posts
Would the AFR 210 76cc heads work ok on a street driven car with a 383 and flat top pistons with a small mechanical roller cam?
Cam specs.
Crower grind # 280R Mech. Roller
Advertised Duration
Int. 280
Exh. 288
Lobe sep. 112
Lift .554 Int.
.567 Exh.
DriveWFO
Do you know if they build the 190 heads with the dual roller springs?
I only see the 210 heads with roller spring set up.
That is why I was leaning towards the 210's
Thanx
Don
call Tony Mamo at AFR, he's working on a new 210 head that is supposed to flow like crazy with really killer low-lift numbers.
Discussion Starter · #6 ·
Bowtie;
I will call AFR today and request some information on the low lift 210 project.
I will post the results.
Thanx
Don
Cam specs.
Advertised Duration
Int. 280
Exh. 288
Lobe sep. 112
Lift .554 Int.
.567 Exh.
Super Chevy built a 355 for their Danger Mouse project. Back in the Dec 2004 issue they used Edelbrock E-Tec 170 heads w/64 cc cumbustion chambers. They also used and eddy roller cam installed @105 deg intake cl (234/238 @ .050), .574/.584 lift and 112 lobe sep. With 10:1 cr, that thing made gobs of low-end torque. Perfect for a street motor. Even for your 383, this would be a great set-up. I think 210/76 cc heads might be too much volume for your cam on the street.
Discussion Starter · #8 ·
I called AFR and they will install roller springs on the 195cc heads.
I think that is what I will go with.
The tech person I talked to said the 210cc heads would work if I increased the compression to about 12:1
I don't want that much compression for my set-up.
Don
Ya I have that article in a book of engine build ups I have...pretty good info...;) :)
Danger Mouse Build
I was wondering if you could email me a copy of the Danger Mouse build as I would like to replicate it.
the 210's will work. Will the 195's work better? yea. Hell I know a guy who has 230 cc runners on his 355. It works.:D
It's a temporary deal. He is going to a much larger shortblock next year.
PS wanna sell the 210's?
1 - 11 of 11 Posts
