Hi everyone,
Looking to build a 383 to replace the 355 I have now that is using oil like crazy. Found the below combination that is supposedly dyno tested and proven. Looks like it can be built for a reasonable price.
Displacement: 383 cu. in.
Carburetor: Holley 750 double pumper
Heads: Air Flow Research 190cc Street
Intake: Air Flow Research FloPower RPM
Camshaft: Comp Cams hydraulic roller, with 236/242° of duration @ 0.050 in. lift, and 0.520/0.540 in. lift
Headers: 1 3/4 in.
Distributor: MSD
Timing: 34°
Comp. Ratio: 9.5:1
MAX HP: 503 @ 5500
MAX Torque: 517 @ 4500
I want a street car that will be taken to the track sometimes. I am running a super T-10 trans now but eventually will go with the tremec TKO. How much difference would the above numbers be with a weiand X-celerator intake and a Holley 650 double pumper card. I already have those on the engine I have.
Thanks for all the help !!
Headers: 1 3/4 in.
Distributor: MSD
Timing: 34°
Comp. Ratio: 9.5:1
MAX HP: 503 @ 5500
