1 - 20 of 32 Posts
1974 chevy. Ova
just got to kicking it around today at work, and wondering who on this site has the fastest N/A 350 sbc. Open to the newer generation of motors (LT-1, LS-1), as long as it's naturally aspirated. I just thought it'd be really interesting to read. i know the mantra "there's no replacement for displacement," but who here's doing "the most with the least?" I'll start:
60' : 1.628
330: 4.723
1/8: 7.355
mph: 92.44
1000: 9.663
1/4: 11.622
MPH: 114.75
i know there's plenty faster here! speak up!
well its not fast enough yet there is still more in it im still working out some issues
60' : 1.750
330: 5.011
1/8: 7.732
mph: 89.90
1000: 10.107
1/4: 12.128
mph: 111.21
oops i forgot im running a 360 c.i. ( 40 over 350 with 5.7 rods and 3.48 stoke crank ) and this is not the fastest mph ive gone ive also been 115.87
Last month I went 10.70 @ 126.+ with my 355, no Nitrous. That was with a 1.51 sixty foot time.
I think it is only appropriate to post your cars weight with a driver to put things into perspective. That and gearing and tire size and trap rpm. I feel bad my car only goes so fast and you guys have smaller engines
Old Brodix Track 1, Victor 4+4 intake, solid roller, 850 Holley, and 12:1 comp. Standard stuff.
thats a good combo lou!!
My old 355 in my 64 went best of [email protected]
LT-1 shortblock, 11 to 1 pistons
pink rods, steel crank
pocket ported 461's
Dema Elgin solid flat tappet cam, .470" with 1.5's
250*at .050" on a 105 LSA
victor jr intake w/ 850 dp
hooker super comps, 1 3/4" w/ 3" exhaust
th350 w/3500 stall converter
4.11's, 26" tall slick
3200# with driver.
at the time all steel car with ralley wheels.
honestly I wished I could have ran the car at the track when I put on a set of 292 turbo heads and a bigger crower solid flat tappet cam. That combo would have easily been in the 11.40 range at about 118-120.
355 SBc
3690LBS
Pump gas
3.73 Gear
100% street car
On muscle
11.71 1/4 mile 114.69mph
On 150 shot nos
10.451 at 128.69
I am racing this guy!!! ( I'm in the right lane!)
7.05 @ 96MPH w/ a 1.54 60'
355 c.i.
-Edelbrock "Bowtie" intake w/ 780 CFM Holley (2" plastic spacer).
-Iron Bowtie heads
-Crane CompuCam Special. Part Number 111411, it's got a 106* centerline, 256 (I) -264 (E) duration and 545 (I)-563(E) lift. Minimum RPM is 4200, Maximum RPM is 7200 (my shift point). 1.5 Harland Sharp rocker arms
-Crower SP91205B (5.7) Rods
-Ross flat tops, heads angle milled .125" (14.1 compression). 2.05 Intake, 1.60 Exhaust valves.
-Zero deck block
-built on 11/11/91, it made 511 hp @ 6800 RPM.
-TH-350 (with UltraBell)
-Art Carr 4200 TC
-5.13 8.5 10-bolt (stock posi)
-C.E. J-hook slapper bars
-28x9 M/Ts on 15x8 Weld DragLites
-Summit brand 90/10s & 50/50s with front sway bar removed
-Fiberglass hood and bumpers
-MSD 6AL ignition
-8 Gallon fuel cell
I haven't had the car weighed, but I would guess 3000-3300 lbs.?
355 chevy,GM block crank and rods,malely 12/1 pistons,630 nos roller OLD elederbrock aluminum heads(probably the first pair they made)team g intake 950 hp holley,turbo 350 thans with a hand me down 8 inch,4000 converter,12 bolt with 410 and 275 d/r on pump gas. I weigh in at 250 and my nova in the 3000 to 3300 area I guess.All steel exect the hood.
Greg
Heres a link of my friends car 282 cuin. 5 speed stick shift car launches at 10,000 rpm's and shift at 9,600
Car runs 6's in the 1/8th and 9.42 quaters
60 ft times are 1.30
Sounds real angry from the time it rolls into the burn box fun car to watch. Cant imagaine driving
Car weights 2,965 lbs with 6.50 gears
Heres the specs on the car and engine
http://www.watsonruppelperformance.com/id5.html
friends just finished .060
350 , 230cc darts , 14-1 comp, 262/269 107 LSA 640 lift cam , super vic with a 850 quick fuel carb , PG with a 7 inch converter , 567 gear , 14x32 slicks , in a 2200 tube S10 is doing 6.21 at 2200 elevation
1974 chevy. Ova
Discussion Starter · #19 ·
355 sbc
ross lightweight pistons
12.5:1 compression
lunati solid flat tappet cam
world products sportsman II heads (untouched)
holley intake
prosystems carb
TH350 transmission
******* converter
TCI full manual reverse valve body
stock 8.5" ten bolt rear
4.56 gear
spool
c-clip eliminators
28*9*15 MT ET slicks
slapper bars
stock leafs
that's last year's set up. it weighed 3280 with me in it this year after removing about 150lbs, so i figure race weight on this setup at 3450. i changed to caltracs/ranchos on the rear and moroso drag springs up front this year, but so far have been fighting fuel delivery and transmission issues (no spin but bad 60ft times).
huh im having the same issues thats weird i got kicked off the track for my trans leaking and my plugs where all white and i jetted up 6 sizes with no coloring what so ever. so im looking at my fuel delivery as well also im running a heidts mustang 2 front clip with a heidts 4 link/bar rear suspension moser 9'' with 3.73 gears and a 3000 stall th350 my car is all steel except for the hood ( harwood 4'' cowl ) the rear suspension has coilovers and the front suspension has c.e. 90/10s up front and im running 255/60/15 mt drag radials
1 - 20 of 32 Posts
