I know the roller is more money so set that issue aside. I just picked up a flat tappet cam-
Int. @ 050 206
Exh. @ 050 218
Advertised Duration: 256 int./268 exh.
Int. Lift 0.432 in.
Exh. Lift 0.459 in.
110 LSA
If I went hyd. roller instead what would I need to change with regard to the cam profiles?
It's a C20 Suburban tow rig with swirl ports so low end torque is key here. The motor will be done by 5K rpms.
Int. @ 050 206
Exh. @ 050 218
Int. Lift 0.432 in.
Exh. Lift 0.459 in.
110 LSA
