As the title states, I’m doing a makeover on my 64 and is a 350 turbo a direct swap for the Powerglide?
Thanks Mark
As far as floor pan clearance I can't help you there, never owned a 1st gen. I think there is plenty of room, but I don't know for sure.
As far as trans swap, car aluminum Powerglide and TH-350 short tail(6" tail housing, 27-5/8" from case face to end of tailshaft housing.) are the same length, have the trans mount in the same location, use the same crossmember, use the same length driveshaft and the same slip yoke spline.
You'll need different shifter linkage, and a slight tweak to the cooler line angles, and dipstick's are trans specific and don't interchange.
If the TH-350 is a stock style automatic shift build with a kickdown cable, you'll need the cable bracket for the intake manifold for the cable.
I appreciate the information, I would like to know about the floor pan clearance also.
Mark
1st gen floor pan clears a TH 350.
Direct fit. Just need to trim the cross member where the oil pan hits it.
Thanks guys, I appreciate the info.
Mark
