When I bought the Nova it had an unknown '74 350. Didn't smoke and ran OK, but I knew it was a low compression smogger motor with 882 heads. I bought a set of 062 Vortecs (already modified for higher lift) with the intention of putting them on with a moderately sized cam (XE274) and RPM intake for a decent street motor with a little power. Going from 76cc to 64cc seemed like it would add almost a full point of compression. This past weekend I did a leakdown test on the motor to check the rings and got around 10% leakdown on the cold engine. Seems pretty solid. But here's where things get interesting. The motor looked bone stock, right down to the paper gaskets and cast iron intake. After the leakdown test I cracked it open and found out that the piston's aren't the stock ones for the block- they are GM 6271097 4 valve relief pistons with a 13cc dish- the ones at the bottom of this page:
http://webpages.charter.net/beckracing/slvpg55.htm
So the last guy replaced the crappy stock pistons with ones that are even worse. Numbers are still on the block so it hasn't been zero decked. Son of a bitch- looks like instead of a 8.5:1 motor it's a 7.9:1. So I'm trying to weigh my options.
Here's what I came up with:
1.) Continue as I was and gamble on a thinner head gasket (.015) and end up at around 9.25:1
2.) Same as above but back down on the cam size to something smaller due to the lower compression
3.) Stop screwing around and get the bottom end rebuilt with flat top pistons (this will waste what seems like a bottom end that's in good shape).
What would you do? Keep in mind that I'm on a tight budget and time to work on this thing is at a premium.
