I would sell both those intakes and pick up an RPM air gap. With a close ratio 4 speed and 3.36's your going to need more torque. I have a 280 degree lobe thats 238 @ .050" with .500" lift. Put it on a 110 lobe separation angle and it will sound good and be driveable.
This is the normal info I need to spec out a cam,
http://www.drcamshafts.com/sinfo.htm
The 331 in the 71 Nova,
350 block with 482 caps + .030"
L2211AF pistons with the domes milled .125" (11.6-1 comp)
5.7 Carillo SJ rods
Small journal 327 crank with spacer bearings
TFS 195 runner heads with some porting.
intake flowed 285 @ .600" with a 2.02"
exhaust flowed 210 @ .600" 1.60"
Camshaft, solid roller 260/268 @ .050" .670"/.630" lift 110 LSA +4 adv
Hooker 1 5/8" headers and dynomax 2-1/2" exhaust.
Rpm air gap intake with a Holley 850 annular carb (11.72 @ 115.5 and 1.62 60 foot)
Ran the super victor with the same holley carb, 11.70 @ 116.7 with a 1.72 60 foot time. The stall speed was too tight for the SV intake. The car was dead until 4000 rpm. With a 225 shot it ran 10.36 @ 132.
