I'm getting ready to buy a set of 28x9 MT slicks and already have a pair of 7 inch Weld wheels.Can you run them on the 7's safely or would you only run them on 8's?
1974 chevy. Ova
8 would be better. 7 will work. minimum recommended rim width for a 28*9*15 m/t is 7.6. you might give M/T a call and see what they say.
I run mine on 6"s to pull in the sidewall for clearance. I ran a 10.22 136 at 5800' last outing. No screws and no tubes. 7's will be fine.
Thats good to here.I have talked to a MT tech rep. awhile ago and he advised against it but have read and heard of guys getting away with it.Thanks for the reply.Anyone else have any thoughts.
The contact area of the tire is usually not complete when the wheel pulls the sidewall in. I have 14 inch tires on 13 inch wheels and it's hard to get the full width of the tire to make good contact to the track.
I run 7's with that size tire and know of a few in the 9's with 7's and that same size tire. it does get a little scary at the big end sometimes because of extra sidewall flex...
I've run 9"s and 10.5"s on 7" wheels--they work better on wider wheels, but it'll work. You have to run lower pressure to get the tread down on the track which does make for an interesting ride on the big end.
