Hey Guys just purchased a 283 engine . The block code is 3756519 and the front date code is FI03ID I was told it's from 61 . It also has 305 Vortec heads on it with a 475 lift cam . What are your thoughts ? I may put it in my 63 Nova .
THANKS
THANKS
There is no substitute for cubic inches. Anything the 283 can do a 350 will do better. Nothing wrong with running a 283 but it is a small engine.
there isn't that many cubes difference from 283 to 350. i have a 327 in my nova an it gets the job done. the numbers, F1031D, thinking that's oct 31st. it's birthday for the motor tomorrow.
not that many
Not that many cubes different :eek:....that 67 cubes, or almost 25% bigger! That's the same difference between a 350 and a 440! That's pretty significant....Sam amount of work to put that or a 350 in it, I wouldn't do it. I would go with a 350.
Depends on what you are going to do with the car. If it's a good engine and you don't need more horse power or torque.. I would use it. If you have to spend a lot of money to rebuild, I would go with a crate 350 probably. Just my 2 pennies.
Yea, I have to agree, there is a huge difference between a 283 and a 350.:yes:
Discussion Starter · #7 ·
The bottom end has been rebuilt . I'm just trying to figure out what I want to do . I have a 350 thats needs rebuilding but with the 283 its already done . So I guess it's about money .
