I've been looking but cant find any info. If you move the leafs in and just move the tub over to the frame. Can you fit a 275 under it? Got a 67 and looking for the direction I need to go before I get to far into it
Yes, I have a minitub moved into the frame rails and run MT 275/50 ET Drag Radials.
Just to be clear, he said, " just move the tub over to the frame".
You said, "minitub moved into the frame rails".
Did you cut into your frame rails & move the tubs over into the frame?
There is a big difference in these two examples.
Mike
Mike
Frame is not notched, just moved the wheel well.
I'm running a 4 link so that wont help you with pics of the spring moved in.
I think the key is moving the shock mount inboard as well though.
