1 - 10 of 10 Posts
Ok well I have my engine built and going from a 250 w/glide to a 350 w/th350 short shaft. I have the new mounts for the block and got a new trans poly mount. but do I need anything for the frame mount? and will the drivehshaft be ok?
i just did a similar swap. i bought new frame mounts. i put the original tranny back in, so i cant help you there.
You need new frame stands thats about it.
When I did my 72 6+glid to sbc + T350 I had no problem reusing the 6 stands and driveshaft.Good luck with the swap.
changing the front spring would be good too.
Don't worry about changing the springs unless you need to anyway. The small block doesn't weigh that much more, and some of the 6 cyl spring rates were actually stiffer than some of the V8 springs.I would wait until your swap is done and see what your height/handling and ride quality is.
From memory BBC 675 LBS
SBC 550
I6 450
Well, i once did that swap of 6L to V8 and had to change coil springs, that´s why i put that comment.
just my 2 cents.
Regards.
my car sat high with the stock 6 cylinder springs after putting my small block in. cut 1 1/4 coil out. i also like my car to sit low though. you should put a stick in it
1 - 10 of 10 Posts
