You have a 230 or 250 engine
don't go by the "block casting numbers".
IT Should have a number by the "dist. pad" ..... something like mine : -- F0709 BC
F = Flint engine plant
07 = month of the year -- (07 = July)
09 = day of the month -- ( the ninth day )
BC = the engine code -- (BC = 250 (155hp) , with p/g)
my block casting # 3921968 -- 230 or 250 , 67 to 75
my car trim tag = " 07C " build date .... = July the third week.
which does match my engine build date of : F0709 .
you HAVE a 230 or 250 motor because of your 4" side covers....
get your dist pad # to determine if it's a 230 or 250 over on
"Nova Resource.com" .
IT IS - NOT a 292 ........
thanks,Jim. I will definitly check out the dist# and that web site. Mine has a th350 trans in it so maybe its not the original engine?
If it has never been rebuilt. Pull the plugs if you see a flat top piston it's a 230. If you see a dish It's a 250.
