mrrepodude said:
Thanks for the info.
With that being said, it will be left stock alond with the powerslide tranny.
With a Powerglide, it will be a slug from 0-60 mph. At the very least step up to a TH350. The extra gear will make a world of difference.
For years I had two '70 Novas in my driveway. My daily driver was an all original 230 six, Powerglide, & 2.75 gear combo. (My weekend car was an SS with a 383.) This went along fine until one day an old VW Super Beetle walked off and left my six banger in the dust.
I had already added an HEI distributor (this helps fuel economy and driveability). I looked over the factory specs for the 230 six to see where I might find more power. From the factory they made 140hp @ 4400 rpm and 220 lb ft @ 1600 rpm. The 230s were low compression (8.5:1) with a very little lift on the camshaft. I decided to go with a bigger cam. Trouble was, all the aftermarket cams looked too aggressive for my needs. I called up Reed Cams and had a custom grind made to my specs. It didn't turn her into a V8 but that extra mid-range power was sure nice.
The stock cam had .332 lift. I wanted more lift without adding a lot of duration. The idea was to get more air into a low compression engine to gain more torque without sacrificing fuel mileage or street manners. The idle still sounded bone stock. Here are the specs.
Reed Cams
Serial #I8974
Grind:TM244HDP
Running Duration: IN 244 degrees EX 252 degrees
Lobe Lift: IN .277" EX .287"
Valve Lift: IN .485" EX .502" @ 1.75 RR
DUR @ .050: IN 198 EX 205
Lobe Centers 108 degrees
http://www.reedcams.com/
In '93, I paid $176.82 for the custom cam and lifters. Two years later, my SS was stolen and I was down to one car. Without the power of a V8 to push me back in the seat, I was like a drunk on the wagon. The withdrawal was too much for me. So I pulled the six (that still was running perfectly), dropped in a V8 (with TPI & 700R4) and the rest, as they say, is history.
