1 - 13 of 13 Posts
I have the factory 230 CID inline 6 with factory everything except what I've recently changed. Which is an HEI Distributer. I still need to put a timing light on it, any suggestions on timing? Also should I change those plugs? They are the same ones from points type distributer.
I like the idea of headers that split into dual exhaust, any recommendations there? Also carb/intake swap? I want a daily driver.
Hi There
If you install or up-grade to HEI ....
You will/should check your plugs. Going from points to HEI ... your plugs need a wider " gap " , like open up to a 35 - 36 gap.
You may not need new plugs -- you choose, if they are in good shape, run 'em ... but, there's only 6 of them -- just buy new ones and reset the gap.
Check out the Holley 4bbl - 390 cfm carb on an OFFY 4bbl intake, running a stock GM exhaust manifold.
#1
#2 ... T-6 Racing carb base plate -- to mount your carb "Front to Back" (instead of running the carb 'sideways').
#3
Langdon's "Cast - Iron split exhaust manifolds"
.......... now offered by '12bolt.com'
#4
Stock 250ci motor, running a T 5 5speed tranny with 3.08 rear.
the end .
Jim, that's a pretty cool set-up. What rear are you running? And if you keep out of the secondaries, ever check the mileage you get? Looks like a good economy/power balance for a 6.
Hi Frank ...... Happy New Year too you.
At this time , I'm just using my stock rear -- 8.2 - 10 bolt / 3.08 gears.
Everything runs / pulls good .... 1st gear = 3.97 , with a 5th o/d = 0.72 .
Back on November 10, 18 .... we drove down to Phoenix for our
Nova BBQ ... and followed 'Poindexter' with his 74 / LS Nova. He got like 24 + mpg , and I got 21.5 mpg.
So, I can get some good mpg ... If I stay off that 2nd gear "scratch" ...... and keep my carb in-check. Having way tooo much fun, and running good ................. spell - that - Happy Camper .
jim
" like open up to a 35 - 36 gap.
You may not need new plugs -- you choose, if they are in good shape, run 'em ... but, there's only 6 of them -- just buy new ones and reset the gap. "
'400Series64' ....
If you go with " HEI " ... "more spark -- more power" !
Then -- you may want to give your 'spark plugs' even more gap ... because of the greater spark produced by the HEI. Like ... a 50 - 55 gap.
sorry .... for miss info .
(ps -- look for more info by checking the "Similar Threads" at the bottom of this page (or any page). Hope this helped.
Going to gap all 6 plugs to 0.055mm. Put a timing light on it and set timing to "0" TDC unless anyone has any other advice on timing or plug gap.
Discussion Starter #9
Nova did well up until yesterday. It almost didn't start back up after a short 15 mile trip in town. Started up fine before trip, drove fine with out any noticed signs of changes. When I went to crank it it would just keep turning over and wouldn't even stumble to fire. (Was only shut off for 5 minutes). After it finally started it ran rough idle but drove fine the 15 miles back home.
Performance Six
I'm building a 230 with 194 head (Compression). Using Clifford Research intake/650cfm carb, and the Clifford long tube headers. BW T-10. And 10 bolt out back with 4:11's
Give the BBC boys a hard time. Ha.
I love all that performance six stuff. S
Me TOOO !
If you don't have u'r T-10 yet ......... You should consider a
Borg - Warner T 5 5speed. A very easy swap and o.d. gear to boot.
Yeah, they say it's not too-tough but ---- for our six's ---- it should work Very Well ........ Mine IS.
How did you make out on this? Did you regap the plugs?
Hey Courn101 . . . . . . If u'r asking " 400Series64 " . . . . . . . FYI - - - - - - his last post was 3 months ago .
Maybe he'll answer up .
(you can see info just by 'clicking on their Picture' ) .
and, WELCOME to SNS . ?
1 - 13 of 13 Posts
