Quick question, I'm going to be installing a 2004r tomorrow and I just tried to move the th350 crossmember back as I've read, to see how it would bolt in. I see two bolt holes close together so I'm assuming the second hole to going back is one of the holes I'd use and I'd have to drill another hole for the furthest back crossmember bolt. The problem I see is if the second of the two holes that are close together is the one I use and I'd have to drill another hole further back would not work because the back bolt hole in the crossmember now sits off the frame. In other words half the hole is over the edge of the frame and the other part isn't over the frame at all. Am I missing something or do I just need to get an aftermarket crossmember or use a th400 crossmember? Also the back part of the frame seems to curve out where the back hole would go, so there is and indentation for several inches in the edge of the frame for the crossmember to sit in and that ends about where the back of the crossmember rear hole would sit.
Hopefully I haven't confused everyone. Thanks for any help or advice.
