401 - 412 of 412 Posts
'63 SS CPP mini with power disc brakes, tubular A arms, 2" lower springs. Unisteer power rack - 185/60/15 Douglas (Goodyear) on '67 Corvette 15 x 6 Rally wheel - 205/70/15 Douglas on 15 x 7 Rally with 4 1/2" BS - 3 leaf spring
Wheel Tire Vehicle Car Window
Tire Wheel Car Vehicle Land vehicle
Tire Wheel Vehicle Automotive tire Car
Tire Automotive lighting Motor vehicle Automotive tire Tread
63 long roof wheel fitment advise
I would like to start dressing up the new 63 Long roof with new rims and tires. Even though my plans have the suspension changing over time, I would like to buy the wheels and tires just once and work on the suspension changes over time. What wheel fitment should I go with given the following:
63 long roof, in line six. Eventually want to go with a LS, but thats at least a year or more away.
5 lug 65' rearend and 65' spindles,with factory drums. Will be getting a CPP mini-sub frame kit later this winter. Next year, plans are to add a Church boys rack.
For the immediate future, I want to drop the factory stance by 1 to 2 inches, all via the springs.
I am debating 15" or 17". My biggest concern for the immediate future is dropping the ride height.
Any recommondations?
Hi 62 convert, without trying to change the subject, can I ask you a question about your plans for the suspension on your wagon. You said you plan on a CPP a mini subframe kit and later add a Church Boys rack. Can you do that? I have a 65 2 door with a CPP front, but with stock steering box. I’d be really interested in adding a rack, but one of the tech guys at CPP suggested not adding one of their racks. Thanks
CPP use to make a special lower control arms that worked with the CBR rack and pinion steering steering kit. That was about 10 years ago.. There have been a few people around here that have that setup.. It’s not very common.
what is the biggest size 15 x 7 wheels will that fit on the front AND the back on a 1965, stock suspension?
I cant for the life of me find any 15 x 7 w/ 4.5" backspace steel wheels anywhere (unless I special order them, and pay a small fortune) , and from what I have read, that is the best size to get. i have found some 4.75" backspace for a decent price, but dont know if they will fit the front or the back. ( 1966-1977 Chevelle Steel COPO Wheel 15 x 7 Black )
i have read hundreds of pots on wheel sizes and my head is about to explode.
Automotive lighting Automotive tire Alloy wheel Rim Gadget
Hello, I have a 64 Chevy Nova. I'm looking to get some Rims and tires. I wanted to get all four wheels 17x7 with a backset somewhere between 4.5 and 4.75 (the standard backset of 4" will rub on the fender when I lowered the rearend) but it seems like this does not come stock. Looks like I will have to pay to have them custom made. Is this true or do I have options?
I have a 64 with P225/60R15's on the rear. On the front, I'm running P195/65R15's on a 15x6" rim with a 4" BS. The fronts just fit without rubbing. I currently have BF Goodrich Radial T/A's on the car. The fronts seem to have slipped belts which I believe is due to the fact that the car sat for roughly 2 years. I would like to replace the tires, but BFG no longer makes the P195/65R15's. My question is, could I run a slightly lower profile tire without affecting anything?
195/6015R....thats what I just got on my 63.
a 195 65 15 to a 195 60 15 has to be very close in diameter. you could call a tire store an they would tell you. say it is a differance of 1/2'' dia. that would only be a 1/4'' in height chance, i wouldn't think that would change the alignment any.
