1 - 3 of 3 Posts
Hi Guys,
I used Energy suspension motor (Energy Suspension - 3.1115R ) and trans mounts on my wagon no movement from the motor
if that helps.
Cheers Ian:uk:
PS Use oem frame mounts if you can aftermarket have a bad reputation for having the holes in the wrong places.
2267 is the industry part number. Part numbers for most brands will have that number as part of their part number.
If you look at a Moroso catalog at their solid motor mounts it explains the differences between the choices. (I'm not recommending solid mounts, just a place for info.) The 2267 is the low height wide between the mounting legs version.
1 - 3 of 3 Posts
