1 - 2 of 2 Posts
Hi Guys,
Just wondering how the factory put the wiring in for the '63 console courtesy light. Could not find a thread on it and did not see much in the manual.
I have the original socket housing with ~1.5' wire. Unsure if it gets taped to the underside of the console, or immediately goes down under the carpet and follows the trans tunnel to the firewall and then to the wiring block.
Thanks for any info or pics,
Rusty
harness
It ties into the roof lamp / door jamb switch harness junction just under the dash drivers side.. The courtesy lamp harness is available from most vendors. There is a small clip by the shift plate that holds the harness to the front portion of the console.. Run the wires under the carpet from there or other wise the wires will be visible .
1 - 2 of 2 Posts
