the lil 260 olds was cute and fun... for about three minutes.
so, i scored an 880 long block complete w vortec heads and factory hyd roller set up. the plan was to clean it, scuff the bores and throw rings, bearings and a cam at it and rag on er.
it was complete minus the intake when i got it for 200$. pretty crusty...
the tear down
crank, skirts and cross hatch all looked good but the oil change interval was obviously not adhered to. all 8 oil control rings were glued into the groove w burnt oil goop. everything seemed to be going ok otherwise and i was stoked to throw this low buck bullet together, until i got to the #5 hole w the stones. i suspect when the intake was pulled water/coolant went in to the cylinder. it sat like that for a few years before i acquired it and the resulting oxidation between piston and cylinder wall left a huge scar in the wall. by the time i honed it to within my low buck tolerances (loose is fast) that piston was rattling around in there like a truck window w no felt.
not wanting to take a chance on a second used engine i contacted Remy at Womack's Engines and cylinder heads in Denham Springs LA. we determined that the crank was within specs and the short
block would get .030 and a set of flat tops.
for the cylinder heads we stayed with the vortecs and opted to lower the stem seal height and machine the spring seats to accept beehives and light weight retainers. i kept the 1.94 and 1.50 valves and had Womack blend the transition area behind the valve seat where the seat transitions to the runner. this is especially effective on the exhaust side. rounded out the vortec mods by adding 7/16 studs and
guideplates. i guess i didnt get photo until they were bolted on...
