Table of Contents - 1974 LS2 Nova Project
As my build thread starts approaching 30 pages, it becomes more difficult for me to surf through the pages to find references to certain parts of the project. So, I got this idea to create a separate thread that is a table of contents to the build thread. This way, I (and others) can quickly jump to the topic of choice. I'll include the link to the contents in my signature so that it is always readily available, and periodically edit/update the contents as the project moves along.
Page 1 - Unveiling, Swiss Cheese roof, LS2 delivery
http://www.stevesnovasite.com/forums/showthread.php?t=200936
Page 2 - Old engine/tranny pulled out
http://www.stevesnovasite.com/forums/showthread.php?t=200936&page=2
Page 3 - Removing frozen brake drums, air shock part number, aluminum wheel polishing
http://www.stevesnovasite.com/forums/showthread.php?t=200936&page=3
Page 4 - Gas tank removal
http://www.stevesnovasite.com/forums/showthread.php?t=200936&page=4
Page 7 - Wiper arm removal, cowl removal, front fender removal
http://www.stevesnovasite.com/forums/showthread.php?t=200936&page=7
Page 8 - Removal of bumpers
http://www.stevesnovasite.com/forums/showthread.php?t=200936&page=8
Page 9 - New roof in place, cleaning rusty parts with acid, paint spray gun
http://www.stevesnovasite.com/forums/showthread.php?t=200936&page=9
Page 10 - 1st attempt at spraying primer, unveiling the LS2, new roof, electric fuel pump
http://www.stevesnovasite.com/forums/showthread.php?t=200936&page=10
Page 11 - Donor parts (includes trunk pan)
http://www.stevesnovasite.com/forums/showthread.php?t=200936&page=11
Page 12 - Removing a gas tank lock without a key, primer painting with a brush
http://www.stevesnovasite.com/forums/showthread.php?t=200936&page=12
Page 13 - Engine stand, proper bolts to put an LS engine on a stand (continued on page 14)
http://www.stevesnovasite.com/forums/showthread.php?t=200936&page=13
Page 14 - Bodywork, frame notching, Dakota Digital dash cluster
http://www.stevesnovasite.com/forums/showthread.php?t=200936&page=14
Page 16 - Completed body work, Seam sealer removal
http://www.stevesnovasite.com/forums/showthread.php?t=200936&page=16
Page 18 - Front suspension tear-down (continued on page 19)
http://www.stevesnovasite.com/forums/showthread.php?t=200936&page=18
Page 19 - Removal of upper ball joints
http://www.stevesnovasite.com/forums/showthread.php?t=200936&page=19
Page 20 - Coil spring removal challenges
http://www.stevesnovasite.com/forums/showthread.php?t=200936&page=20
Page 21 - Removal of steering linkage parts, Purchase of used 220 volt air compressor
http://www.stevesnovasite.com/forums/showthread.php?t=200936&page=21
Page 22 - Listing of time and costs to date, experiments with home-made soda blaster
http://www.stevesnovasite.com/forums/showthread.php?t=200936&page=22
Page 23 - Drying system for air lines, first use of media blaster, blasting details
http://www.stevesnovasite.com/forums/showthread.php?t=200936&page=23
Page 24 - Prep/paint the subframe, List and cost of suspension parts
http://www.stevesnovasite.com/forums/showthread.php?t=200936&page=24
Page 25 - Urethane bushings, Home made blaster "cabinet"
http://www.stevesnovasite.com/forums/showthread.php?t=200936&page=25
Page 26 - Installation of Pitman arm and idler arm
http://www.stevesnovasite.com/forums/showthread.php?t=200936&page=26
Page 27 - Truck bed paint, Installation of upper A-arms, Gas pedal removal, coalescing air dryer
http://www.stevesnovasite.com/forums/showthread.php?t=200936&page=27
Page 28 - Coil spring installation, home made spring compressor, body bushing removal
http://www.stevesnovasite.com/forums/showthread.php?t=200936&page=28
Page 30 - Smoothing the firewall
http://www.stevesnovasite.com/forums/showthread.php?t=200936&page=30
Page 31 - Installation of steering gearbox, sand blasting the roof, painting the roof with epoxy primer, hatch cleanup and painting
http://www.stevesnovasite.com/forums/showthread.php?t=200936&page=31
Page 32 - Paint removal, prep work, and spraying primer (multiple pages)
http://www.stevesnovasite.com/forums/showthread.php?t=200936&page=32
Page 36 - The land of Bond-O (multiple bodywork pages)
http://www.stevesnovasite.com/forums/showthread.php?t=200936&page=36
Page 40 - Techniques for building a curve with body filler
http://www.stevesnovasite.com/forums/showthread.php?t=200936&page=40
Page 42 - New home for me and the Nova
http://www.stevesnovasite.com/forums/showthread.php?t=200936&page=42
Page 44 - Steering column removal
http://www.stevesnovasite.com/forums/showthread.php?t=200936&page=44
Page 46 - Steering wheel removal, steering column disassembly/refinishing
http://www.stevesnovasite.com/forums/showthread.php?t=200936&page=46
Page 47 - HVAC system and ducting disassembly and removal
http://www.stevesnovasite.com/forums/showthread.php?t=200936&page=47
Page 49 - HVAC control disassembly and rebuild
http://www.stevesnovasite.com/forums/showthread.php?t=200936&page=49
Page 50 - Dash bezel disassembly, including light and wiper controls
http://www.stevesnovasite.com/forums/showthread.php?t=200936&page=50
Page 51 - Gauge cluster installation; Refurbishing the dash pad
http://www.stevesnovasite.com/forums/showthread.php?t=200936&page=51
Page 55 - Steering coupler (rag joint) rebuild; Holley oil pan installation
http://www.stevesnovasite.com/forums/showthread.php?t=200936&page=55
Page 57 - A/C evaporator, dryer, and suitcase refurbishing
http://www.stevesnovasite.com/forums/showthread.php?t=200936&page=57
Page 59 - Holley LS engine mounts, low-mount alternator clearance/replacement
http://www.stevesnovasite.com/forums/showthread.php?t=200936&page=59
Page 62 - Installation of LS2/4L60E into the car
http://www.stevesnovasite.com/forums/showthread.php?t=200936&page=62
Page 68 - Refurbishing the steering wheel
http://www.stevesnovasite.com/forums/showthread.php?t=200936&page=68
Page 69 - Rearend removal and Dana 60 prep
http://www.stevesnovasite.com/forums/showthread.php?t=200936&page=69
Page 80 - Brake system installation and bleeding
http://www.stevesnovasite.com/forums/showthread.php?t=200936&page=80
Page 83 - Rear disc conversion on Dana 60
http://www.stevesnovasite.com/forums/showthread.php?t=200936&page=83
Page 84 - LS2 / PSI wiring harness
http://www.stevesnovasite.com/forums/showthread.php?t=200936&page=84
Page 91 - Off to the custom shop
http://www.stevesnovasite.com/forums/showthread.php?t=200936&page=91
Page 95 - Chasing electrical gremlins
http://www.stevesnovasite.com/forums/showthread.php?t=200936&page=95
Page 97 - Refurbishing and upholstering a bench seat
http://www.stevesnovasite.com/forums/showthread.php?t=200936&page=97
