1972 nova
In the middle of building my '72 Nova right now. Just had the bottom, floors, trunk, and firewall soda blasted. A little finessing and some seam sealer, and chassis black sprayed on the whole lot. Body has been blocked, all jambs sprayed and ready for final fitmemt after I get the springs mounted in the front subframe. New disc brake kit from RIGHT STUFF (4 wheel) with tubular control arms already in place on the powder coated subframe. Had the rear end blasted too and painted cast grey. All the little bits (rad support, headlight buckets, inner fenders, braces, and so on painted chassis black as well. 355 with aluminum heads being transplanted from my '66 into it soon along with a new Richmond 5 speed and Hays dual clutch. Getting new 3:08's for the rear because first gear is really low and 5th is 1:1, same as conventional 4 speed. Works out to 3:81 in first gear so it should work well together. I'll,post some pics when I get a chance
