So my '70 SS had a damaged subframe & I picked up a '74 Omega subframe to use. After going over anything that could be different (I thought) I am in the final stages of reassembly and apparently the clutch z-bar plate that bolts to the side of the subframe is different. This is the stock Nova piece 1968-1974 Nova Clutch Z-Bar Frame Bracket
The only three factory mounting holes in the Olds subframe do not come close to lining up with the three holes in this piece. So I am just wondering if anyone else on here has used the Olds subframe with a stick or could shed some light on whether they might have used a different z-bar plate than the Novas?
