SOLD!!! 1970 Chevrolet Nova SS
Body- All steel, New--- Slick Hugger Orange Paint, New Bumpers, Stainless Trim, Aluminum window moldings straightened and re polished, headlight bezels, marker and headlights lights are new. New door handles. All lights are LED.
Chassis---Competition Engineering Shocks, Subframe connectors, Slid-a-links and Upper control arm bushings, poly Sub Frame Bushings, Moroso Trick Front Springs, 3 Leaf springs out back, MPB Four wheel disk brakes. This thing stops!!
Interior--- New--BMW front seats (very Comfortable), rear reupholstered to match front in Italian leather, new door panels, Armrests and carpeting, Covans Dash upgrade w/Autometer Pro Comp II Gauges, Hurst pistol grip shifter. Very nice!!
Engine---406 SBC Bad fast and dependable!!
.30 ARP studded block, Line honed and torque plate finished ALL ARP hardware!
SRP PRO flattop 271065 pistons, Brand new JE rings
Lunati light weight 4340 crankshaft Eagle H-beam rods, ATI balancer, Brand new bearings All balanced within a 1/2 gram!!!
AFR 210 CNC chamber and CNC Comp port with PAC springs and Manley SS valves, guideplate and Jomar stud girdle, CME Titanium retainers and locks, New valve job and seals! Crower Stainless Steel EURO rockers
Doug Herbert Solid Roller Intake
Dur Int-Exh 285/290
Dur @ .050 Int-Exh.245/255
663 @ 1.7 lift intake
660 @ 1.65 @ 1.65 Exh
Lobe center: 106
4X7 Swap
Double roller timing chain
Crane REV Kit
Melling M-99HVS oil pump with 68lbs spring
Hamburger oil pan #1088
Holley Dorton 300-110 Intake w/2" spacer
Holley 750HP Series Carburetor
MSD PRO-Billet Distributor 85551
Mallory Digital High Fire ignition #685, Mallory Coil
Transmission---Tubo 400 W/manual valve body, TCI #241002 Super Street Fighter Stall Converter, Hurst Pro Stick W/Pistol grip, Trans-cooler
Rear End---Factory 12 Bolt W/373 Pro gear, Moroso brute strength Posi unit and Moser Axels
Exhaust-- 1 7/8 Hooker Super Comps, Stainless Steel 3.0 inch mandrel bent W/Flowmasters Super 44 exit behind tires
Wheels-- Weld Drag Light Stars Font and Rear, Rears have M/T 275/60/15 drag Radials that flat out hook!!!
Electrical-- One wire high output Alternator, Power Master high torque starter, trunk mounted Optima Battery
Fuel System--Summit 15 gallon fuel cell, Aeromotive Electric Fuel Pump and return regulator system. Can handle 850HP
Cooling System-- Champion 3 core high flow radiator, mechanical fan w/clutch, runs 185 all day in hot weather.
Brakes-- 4 wheel disk brakes at all 4 corners.
All LED lights with Orange Halo's in the front.
I'm sure there's a ton I forgot to list, Motor is fresh less then 100 miles on it!
This is a very dependable, fast and consistent street car. You can idle all day in a parade or take it to the track..
10.76 @ 124 mph 1/4 mile
6.99 @ 99.903 mph 1/8 mile
Videos available upon request.....
Dur Int-Exh 285/290
Lobe center: 106
4X7 Swap
Crane REV Kit
