I have the car and the transmission. I want to talk or correspond with someone who has done this transmission swap.
Major problems that I see are:
(1) Hooking up the TV cable as the linkage is on the intake manifold instead of the 1bbl carb. Possibly a newer carb with linkage on it? Don't want to go to a aftermarket intake, unless necessary.
(2) what flex plate to use.
(3) will old trans crossmember work?
(4) what trans mount will work?
My car is a standard shift, 68 Chevy II, with the 230 c.i. engine.
I have a column shift from a 68 that was automatic, so that shouldn't be an issue.
I know the 200-4R will bolt to my engine (came out of a 85 Buick LeSabre).
Any help appreciated, Lou at 501-835-1513 email [email protected]
