Your 67 wire diagram is almost the same as my 66. I wish I had a way to scan it in. The big differance I see is a red 12 gage wire coming of the starter solenoid and going to the fire wall. They dont show where it goes after that so I assumed it was what feed the fuse panel. But after looking at yours and a few others it seems to get power to the fuse panel thru the horn relay. Am I right? I should have said I have converted over to a 1 wire alternator and HEI ignition. So all I will have is the purple wire and large battery feed going to the starter solenoid.
It sounds like someone re-engineered your system in the past and ran the main fuse box feed wire directly to the starter. Is your 12g red wire from the fuse box connected to the main battery feed post on the starter? If so, that ain't the original setup. :no: It'll work, but it's not original.
How is your horn relay hooked up today?
The horn relay is the OEM location used to feed the fuse box. A wire usually runs across the core support from the battery to feed the horn relay. There should be a fusible link plumbed between the fuse box feed and horn relay also in order to keep things from melting down from a dead short. If that's missing, then definitely someone has played with the setup.
Converting to an HEI and 1-wire setup wouldn't have altered the wiring configuration very drastically. Some wiring would need to be removed/altered slightly to make that setup work properly, but it wouldn't have required anything to be reconfigured very drastically. It shouldn't have required feeding the fuse box from the starter solenoid.
Am I helping at all here? :turn:
