Here is a pair of 1965 Nova Peak extensions that have been restored. Both the drivers and passengers side piece has been sent out to be repaired, polished and re-anodized with the original finish.
Both of these will need a little massaging to get them to fit properly due to the dent repairs that were needed to get these looking good again.
You will see the drivers side has some pitting on the inside edge and a slight crack that has started, also on the inside edge. You can see this in the 7th and 8th pictures.
The passenger side has an imperfection that I think the repair shop did, it is on the top inside edge. In addition, the lower third section has a slight bend to the required repair.
I would like $450 for this pair.
I also have the top peak mouldings that have repaired, polished and re-anodized with the original finish, that would match up nicely with the curved peak extensions.
If you happen to want a better set of peak extensions or a lower quality set, I can help with that.
Rectangle Metal Grass Font Circle
Natural material Wood Terrestrial plant Fashion accessory Metal
Wood Natural material Twig Rectangle Metal
Wood Metal Twig Fashion accessory Grass
Natural material Wood Metal Tool Nickel
Natural material Household hardware Metal Fashion accessory Titanium
Wood Natural material Metal Fashion accessory Musical instrument
Wood Cosmetics Metal Hardwood Baize
Writing implement Wood Pen Office supplies Varnish
Wood Automotive exterior Metal Natural material Office supplies
Thanks,
Frank
