1 - 20 of 28 Posts
1964novass - 1964 Nova SS - Factory V8
Year: 1964
Model: Nova SS
Engine: 414 SBC - Bowtie block 4.125 bore, 3.8750 stroke Scat forged crank, 6" H beam Scat rods, AFR 210 Eliminator Race Ready Aluminum heads, Comp Cams Hyd. Roller Cam, Motown intake, Nickerson Performance Carb, pump gas 93 octane
Body/Exterior: Viper Red, Painted back in the 90's at Wisser Autobody Northampton, PA
Front End: Stock front clip with CPP upper and lower control arms, 1" sway bar, Moroso trick springs, Calvert 90/10 shocks, Unisteer rack and pinion, Wilwood disk brakes
Transmission: Turbo 350 Built at Competition Transmission in North Tonawanda. New York
Rear End: 9 in. Moser case, Moser 35 spline axles, Strange center section, 3.89 gear, Detroit Locker, Explorer Disk Brakes, Split Mono leafs, Caltracs and Rancho Adj. shocks, rear sliders, mini tubbed
Exhaust: Hooker Super Comp fenderwell headers, full 3" aluminum exhaust with Vibrant aluminum mufflers
Wheels/Tires: Front: 17x7 Torque Thrust II with 205/50/17 tires
Rear: 18x8 Torque Thrust II with 275/40/18 tires
For the strip - Rear:15x10 Weld Prostars with 27x10.5 Hoosier Quick Time Pros
Front: 15x3.5 Weld Prostars with M/T front runners
Interior: All stock full interior with 10 pt. roll cage with swingout bars
Electrical: American Autowire
Accessories/Options: Factory V8 car originally with a powerglide trans.
Sound system: Stock 1964 push button AM (not hooked up, just for looks)
Additional Comments: I still have a few things to do, but I would like to thank the guys on this site that have helped me out. I couldn't have done it without you. If anyone has any questions, PM me. I have a ton of Nova information that I have aquired over the years. The best pass I have had on the car so far is 10.83 @ 124 mph.
1 - 20 of 28 Posts
